Mattwood
Dec 30, 2020Aspirant
Readynas DLNA Playlists helps with Our Jukebox
Hi everyone
Im looking for some help on readynas DLNA playlists
i got an amazon echo dot for xmas ...whoohoo awesome..kind wify :)
i have all my music on my Readynas\music with DLNA setup. and ...
- Jan 02, 2021
Hi StephenB Thanks for your help,
after some extensive research i have manage to get "Our Jukebox" (for alexa) to pick up M3U playlists...HoooRahhh!
after reading some of the threads on here, someone was using a Playlist creator 3.6.2.
i thought after pulling my hair out i'll give it a shot.
Downloaded and did some tests..Note Playlist Creator will only load Mp_3 files would not load W4a or wma files. :( but any who i still have lots of mp_3 files and not the end of the world.
so anyone stuck on this, i got this working. after looking at the M3U in a txt editor like notpad i found the below:
#EXTM3U
#EXTINF:273,Heart Shaped Grenades - 1 - Chains
..\Buried By My Heartache\Heart Shaped Grenades\Chains.mp_3
#EXTINF:253,BBMH - 1 - Choke
..\Buried By My Heartache\BBMH\Choke.mp_3
#EXTINF:304,Hail to the King - 2 - Hail to the King
..\Avenged Sevenfold\Hail to the King\02 Hail to the King.mp_3though i managed to type out the full file path, the only way i could get it working, appoliges im not very good on the lan networking side and IP addresses but i managed to get it work this way also
#extm3u
#Extinf:273,Heart Shaped Grenades - 1 - Chains
smb:\\Your Nas IP\music\artist folder\album folder\track file.mp_3
NOTE: once the file had been finished in "Our Jukebox" you must clear the search filter a few times then re-index and then download the .html log and check if it seen the playlists.
Hope this helps anyone
cheers matt
Dec 31, 2020Guru - Experienced User
There is an old thread here that might help: https://community.netgear.com/t5/Using-your-ReadyNAS-in-Business/ReadyNAS-use-Playlists/td-p/832459
