Croftcroyne
Jun 07, 2020Aspirant
ReadyNAS Duo - Can't boot, fan running fast
RND2110-100UKS with 2x 1Tb drives, now 5 yrs old. Today switched on a couple of hours ago, fan running fast, power blue light flashing, and unable to access from Windows 10 (using RAIDAR 6.5.0 which ...
Croftcroyne
Eventually pulled the plug, now running and accessible via RAIDAR. Do I need to be concerned? No email received from the device.No error message in logs on admin page and all seems healthy. ??
Jun 07, 2020Guru - Experienced User
It's an old NAS, and of course it isn't supposed to run that way.
Do you have a backup plan in place for the files?
Also, I suggest downloading the full log zip file, and looking in there for errors. The summary in the web ui leaves out a lot of stuff.
- CroftcroyneJun 07, 2020Aspirant
Hi Stephen, Thankyou. The logs failed to download, and then I couldnt access the admin, switched off and on but failed to connect with RAIDAR sometimes RAIDAR sees it and tells me the disks are fine, but I am unable to browse or log in. Is there anyway, if I remove a disk and plus into windows that the OS would read it?
- StephenBJun 07, 2020Guru - Experienced User
You could try connecting drive 1 to a PC, and then access the files with R-linux for Windows. https://www.r-studio.com/free-linux-recovery/
Thankyou Stephen, I am trying ReclainMe File Recovery https://www.reclaime.com/library/nas-recovery.aspx which seems to be finding my files, I'll report whether it finds everything, and can be saved. Most files but not all were backed up to OneDrive!
