BillC34
Jul 02, 2022Aspirant
ReadyNAS Duo Connection to Chrome OS
I cannot connect my ReadyNAS Duo v2 to my Chrome OS Pixel Slate. Windows 11 no longer supports connection to the ReadyNAS (I can still see the contents via the RAIDar 4.3.8 app on Win 11 but can't e...
- Jul 02, 2022
Let's start here, as many owners of the original Duo mistakenly think they have a v2. That is on Netgear, the labeling is confusing.
A Duo v2
- Says ReadyNAS Duo v2 on the front panel
- Runs 5.3.x firmware
The original Duo (called v1 here)
- Says ReadyNAS Duo on the front panel
- Runs 4.1.x firmware
Your options for dealing with the setup problem do depend on the ReadyNAS model, so getting this right is important.
BillC34 wrote:Windows 11 no longer supports connection to the ReadyNAS
This isn't about Windows, it's about the browser(s).
The legacy ReadyNAS (including both Duos) only support TLS 1.0. That is outdated, and browsers are beginning to require TLS 1.2.
If Internet Explorer is still on your system, you should be able to access the admin web interface with that. You can also use Edge in IE mode. https://docs.microsoft.com/en-us/answers/questions/450116/how-to-enable-ie-mode-on-microsoft-edge.html
Another approach is to install an old browser version - FireFox is convenient, because Mozilla maintains a complete archive of old Firefox versions. Version 94.0.2 works. If you do this, immediately reconfigure it to prevent it from auto-updating.
As a reminder, you don't need to use the setup button in RAIDar (which always launches the default browser). You can just browse to https://nas-ip-address/admin (using the actual NAS IP address of course).
There are some other options to maintain access to the web admin UI, but they do depend on which NAS you have.
BillC34 wrote:
I would like to connect the ReadyNAS shares to my Pixel Slate but it won't add the share.
While I don't own a Slate (or any Chromebook), I did take the time to google this.
It appears to be similar to the browser problem. Your very old ReadyNAS is limited to SMB 1 support. New products use SMB 3. As you likely know, Microsoft still lets you enable the SMB 1 client in Windows (in "turn windows features on or off". But I believe the Pixel Slate simply doesn't support SMB 1.
I don't know if the Pixel Slate supports NFS shares - if it does, then you could try enabling NFS sharing on the Duo. FTP or HTTP sharing might also be an option.
Jul 02, 2022Guru - Experienced User
A Duo v2
- BillC34Jul 03, 2022Aspirant
My ReadyNAS is in fact a Version 1 machine despite the plate on the back. I had no luck using Edge in IE mode, but I have been able to access https://nas-ip-address/admin using the old version of Firefox and TLS 1.0. Having enabled SMB 1 support I can now map a network drive to the ReadyNAS shares using Win 11 File Explorer, so full access to the ReadyNAS is available in Win 11.
Many thanks for your very helpful reply (I remember your help from the old days of the Digital Entertainer Elite - I still have mine gathering dust). I'm now off to the Pixel Slate community in search of SMB 1 support (Firefox on Chrome OS has partial access to the ReadyNAS but no shares are showing up).
- StephenBJul 03, 2022Guru - Experienced User
Surprisingly, mine is still in use!
Interesting. Frontview (https://nas-ip-address/admin ) doesn't provide access to the shares. But if you enable http sharing for a share in frontview, then you should see it at http://nas-ip-address/shares.
FWIW, the label on the back means it is "hardware revision 2 of the original Duo". Very confusing.
This does limit your options. You can just continue to use the old firefox. If you change a configuration file via the linux command line interface, you can also turn off the redirection to https when you access frontview. Then http://nas-ip-address/admin will work from any browser (but https will fail from the new ones).
More info on how to do that is here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/Workaround-for-ERR-SSL-VERSION-OR-CIPHER-MISMATCH-problem-for/m-p/2198243
- schumakuJul 03, 2022Guru - Experienced User
The formal way toe use SMB on these newer chrome OS (and the like) devices does work with the files application:
https://support.google.com/pixelslate/answer/9172501?hl=en#zippy=%2Ccloud-storage - open the vvv Cloud-storage section
Your device works with cloud file systems, like Google Drive, Box, or SMB. To connect to an SMB file share:
Laptop mode: In the corner of your screen, select the Launcher Launch icon and then Up arrow
Tablet mode: Go to the home screen. To get there, tap the Launcher Launch icon in the lower left corner of your screen.
Open Files
In the top right, select More
Select Add new service and then SMB Shares.
A window will open. Select Add File Share. Fill out your info.
Select Add.===
On older Chrome OS, this was an experimental feature, which could be enabled manually:
Navigate to chrome://flags/#native-smb in your browser and change the dropdown for “Native Smb Client” to “Enabled”. It’ll prompt you to restart Chrome — go ahead and do it. then it's the same Files App.
Going back in time even more, on older-older Chrome OS and Android there were some user space apps, too.
