AaronThurling
Aug 12, 2020Aspirant
Readynas Duo constantly resynching volume
Readynas Duo RND2000 v1, the act light is constantly active, so upon checking the logs i find that the device appears to continually find and fix errors on volume C then a resync begins that takes ma...
Sandshark
Aug 12, 2020Sensei
Try (with power off) removing and re-seating the drives. That can also happen if one drive wakes from sleep much slower than the other. Is one drive a "green" one and the other not? Try disabling drive spin-down (if it is currently enabled) and see if that makes a difference. Unfortunately, that can also be a sign of a failing unit, possibly just the power supply, but equally or more likely something else.
