steve37066's avatar
Apr 27, 2022
ORBI350 continuely resynching
ORBI350 with 1 satellite, both on firmware v4.4.0.10_2.10.63.
Router is in APmode.
Recently I find the satellite is very often in synchronising mode. That is to say that the white LED starts flashing then the blu LED lights up for the regular 3 minutes before going out.
Is this behavior normal as I hadn't noticed it before?
Have been using this mesh only for the last 3 months.
Thanks
steve37066
  • plemans's avatar
    Apr 28, 2022
    I'd try 1-6-11.
    Not sure what you're options are for 5ghz and I don't have a dual band version to test with
  • plemans's avatar
    Have you tried moving the satellite around? or closer?
    Maybe there is a sync issue.
    • steve37066's avatar
      steve37066
      Tutor
      Hi,
      Have shifted the satellite about 6ft closer (router and satellite are now less than 30ft apart) but still having the same problem. Note that this has been happening only in the last week or so after about three months of perfect functioning. There hasn’t been any changes in the original configuration.
      • plemans's avatar
        Have you tried changing wifi channels?
        the 350 series is dual band without the dedicated backhaul. maybe there's interference
