kesch
Aug 19, 2021Aspirant
ReadyNAS Duo IP address
Can't connect to new router. IP address seems to be 192.168.1.12. Is this static? Can I make it dynamic?
kesch
Sep 07, 2021Aspirant
I didn't want to disturb the router. I connected the ReadyNAS directly to my laptop using the ethernet port with a fixed IP setting of the NAS, 192.168.1.12. RAIDer now works but I can't get 192.168.1.12/admin tab to connect from my Chrome browser. I tried turning off all Windows firewalls and I exempted the NAS IP from security scans from Sophos, no change. Any other ideas?
Sep 08, 2021Guru - Experienced User
RAIDar should have worked before, since it uses ethernet broadcast (and not IP) to find the NAS.
You need to set the laptop to use a compatible IP address. For instance, temporarily set it to use 192.168.1.10, with a subnet address of 255.255.255.0 and a gateway address of 192.168.1.1.
Or change the plan, and use 192.168.0.x in the router (which you can make permanent if you like).
