ZosoOfZep
May 30, 2012Aspirant
ReadyNas Duo processor type
Hi,
I have a ReadyNas Duo v2 ( I think, as it has a v2 on the backpanel) and would like to know what processor it has.
I assumed it had an ARM installed but looking at my RAIDiator version number it doesn't correspond to the ARM version, details below:
Model: ReadyNAS Duo [X-RAID]
Serial: 24M29772008B9
Firmware: RAIDiator 4.1.8 [1.00a043]
Memory: 256 MB [2.5-3-3-7]
Can anyone shed any light on this?
Cheers
Cheers
- StephenBGuru - Experienced UserThe label on the backpanel is (regrettably) misleading. You have a Duo V1.
You can look at all the ways to tell here: http://www.rnasguide.com/2012/01/09/how ... -or-nv-v2/
However, the firmware version tells the story.
Did you purchase recently? - ZosoOfZepAspirantThanks for the reply.
I purchased it just over a year ago.
Do you know if I can run PHP on a V1?
Cheers - StephenBGuru - Experienced User
A year ago was before the V2 was launched.ZosoOfZep wrote: Thanks for the reply.
Cheers
You can run php on the v1 series, there is an add-on here: viewtopic.php?f=47&t=54543 - ZosoOfZepAspirantCheers, thanks for the info.
