pjrothwell
Jun 13, 2018Aspirant
ReadyNAS Duo RND2110v2 model compatibility?
Hi all. My trusty old ReadyNAS Duo, that has served me well for several years, has died suddenly and I need some advice on an equivalent replacement please. Underneath the unit it says the model nu...
- Jun 13, 2018
Hi pjrothwell
Welcome to the Community!
It would be better if you can find a Similar model which is the RND2110v2 (Duo V2 with 1x1TB) or the diskless model RND2000v2 (Duo V2). But IMO it's best to go with an OS 6 model which are way better than the older models since it only supports SMB1 and no further firmware updates will be available. The RND2120 and RND2150 is on a different architecture and software than your Duo V2 so it is not possible to migrate the disks. But you can check if you really have a Duo V2 or V1 by checking this page.
You can migrate the disks from your RND2110v2 to an OS 6 model like the RN200, RN400 and up series. You will just have to properly setup the NAS using this guide and/or contact support for assistance. (There's a 90 day support contract included for Brand new purchases). Note: Your disks should be in healthy condition in order for the data to properly be recovered.
But again if you just want to have the disks inserted and get the NAS running then getting the same model as with your old NAS would be the way to go.
Hope this helps!
Regards
Marc_V
Jun 13, 2018NETGEAR Employee Retired
Hi pjrothwell
Hope this helps!
Regards
- pjrothwellJun 13, 2018Aspirant
Thank you very much for the quick reply. Very helpful.
