rufo007
Aug 20, 2011Aspirant
[ReadyNas Duo] Static IP / DHCP Problem
Just today I have changed my ReadyNas Duo from a network with static Ip assigning for wired connections to a network where the IPs are assigned by DHCP. Now, I am not able to see my netgear in the ...
PapaBear1
Aug 20, 2011Apprentice
Do you know what the current static IP number is?
If not, can you reconnect to the old network, access Frontview on the Duo and change the setting to DHCP and then shut it down and move it?
