rufo007
Aug 20, 2011Aspirant
[ReadyNas Duo] Static IP / DHCP Problem
Just today I have changed my ReadyNas Duo from a network with static Ip assigning for wired connections to a network where the IPs are assigned by DHCP. Now, I am not able to see my netgear in the ...
PapaBear1
Aug 20, 2011Apprentice
Have you tried turning on the Duo and then opening RAIDar on a PC? RAIDar will find any NAS on the network regardless of the subnet and after the NAS has fully booted will report the fourth column (IP Address). If RAIDar does not find the Duo, then something else is wrong.
In that case, connect the Duo directly to the NIC of a desktop and load RAIDar. RAIDar should find the Duo (if it is on, regardless of the subnet).
If RAIDar does not find the Duo in that situation, check that the small lights at the NIC socket are on. They should be on for both the PC and the Duo.
