rufo007
Aug 20, 2011Aspirant
[ReadyNas Duo] Static IP / DHCP Problem
Just today I have changed my ReadyNas Duo from a network with static Ip assigning for wired connections to a network where the IPs are assigned by DHCP. Now, I am not able to see my netgear in the ...
sphardy1
Aug 21, 2011Apprentice
A firmware reinstall will reset the NAS to obtain its' address via DHCP without changing your NAS setup (other than your admin password will also be reset)
Then you can use RAIDar to connect
See the FAQ for instructions of how to reinstall the firmware
