st_1
Mar 08, 2017Aspirant
ReadyNAS Duo v1 and Seagate Ironwolf - not working?
Message: I find that Seagate Ironwolf ST2000VN004 does not work with (old) ReadyNAS Duo v1. Does anyone have other opinions? In a previous thread (autumn 2016), I asked for spec for replacement d...
- Apr 12, 2017
The Seagate Ironwolf has now worked full-time in the ReadyNAS Duo for more than 4 weeks.
And it even reports lower temperature than the WD drive it is sitting next to.
I can therefore confirm that the Seagate Ironwolf ST2000VN004-2E4164 2TB NAS drive does indeed work with the ReadyNAS Duo v1 with RAIDiator 4.1.15 (lastest FW as of today).
mdgm-ntgr
Mar 08, 2017NETGEAR Employee Retired
Have you tested the disk using SeaTools?
Whicjh firmware are you running on your Duo?
st_1
Mar 09, 2017Aspirant
No, not yet on a PC. But the disk spins up and see lights on the board.
Will report back.
> Which firmware are you running on your Duo?
The latest available. I tried upgrading a week ago, and "no new SW available". I will check the numbering later today.
