st_1
Mar 08, 2017Aspirant
ReadyNAS Duo v1 and Seagate Ironwolf - not working?
Message: I find that Seagate Ironwolf ST2000VN004 does not work with (old) ReadyNAS Duo v1. Does anyone have other opinions? In a previous thread (autumn 2016), I asked for spec for replacement d...
- Apr 12, 2017
The Seagate Ironwolf has now worked full-time in the ReadyNAS Duo for more than 4 weeks.
And it even reports lower temperature than the WD drive it is sitting next to.
I can therefore confirm that the Seagate Ironwolf ST2000VN004-2E4164 2TB NAS drive does indeed work with the ReadyNAS Duo v1 with RAIDiator 4.1.15 (lastest FW as of today).
st_1
Mar 09, 2017Aspirant
Indeed.
Unfortunately that list has not been updated in several years, meaning most models on the list are no longer in production.
In fact, the old disks I have are both some of the largest on the list (WD 2TB and Seagate 2TB).
In posts from the Autumn it was confirmed that the later WD20EFRX does work with the ReadyNAS Duo, and speculated that the IronWolf *should* work. I will try and check the disk itself today or tomorrow to see if it is a HDD problem after all.
st_1
Mar 11, 2017Aspirant
Interesting developments in the storyline:
1) after the unit failed to cold-boot with the Ironwolf installed, I tried swapping back and forth between the failed disk and the Ironwolf to assure that the ReadyNAS itself was still working. (It was).
At the third swap, I think, I gave the failed disk a "rotary shake" around the axis of rotation of the disk, just for the hell of it.
...and lo and hehold, the disk came back to life with the ReadyNAS, and starting a Resync. :smileysurprised:
I let it run, and it is now working as before. Nothing in the Logfiles or the SMART-information shows signs of failure in the past.
2) I checked for new software, and surprisingly, a new software was suddenly avaialble. (4.1.15)
I don't understand why this was not flagged in the autumn, as I believe this version is available since more than a year ago.
In any case the systems updated and came back up again.
I will need to consider my options now...
- st_1Mar 16, 2017Aspirant
More developments:
As per recommendation, I finally gave up on the Ironwolf in the ReadyNAS, and dug out a PC.
The Ironwolf turns out to be a dud.
Testing with SeaTools yields "disk is not responding to commands".
Ok, DoA notice to vendor, and new dish arrives this morning.
Attach new disk to PC to verify that it *is* indeed working (which it was).
Pop one disk out of ReadyNAS, swap, pop new Ironwold into ReadyNAS... and resynch starts.
After 9 hours, unit it now mirrored and fully operational.
Soooo....
a) The Ironwolf 2TB works in the ReadyNAS Duo v1.
b) Getting an (almost) dead Ironwold wreaks havoc with the installation process. Took some effort to nail the problem.
Thanks, guys, for suggestions and advice.
st_1
- st_1Apr 12, 2017Aspirant
