Numb3r6's avatar
Numb3r6
Apprentice
Feb 13, 2019
ReadyNAS Duo v1 boot fail into "Volume scan found and corrected errors"
This is a ReadyNAS Duo v1 -Bootup via Power Timer, as usual, no errors reported or emailed to me -First use of NAS was to stream music to a mobile device. Done it many times, no issues. This tim...
  • StephenB's avatar
    Feb 14, 2019
    I wouldn't be concerned about lp stat events.
    A volume scan is a reasonable idea, though I'd suggest making a backup (or updating it if needed) first.
