bethjim
Sep 28, 2016Aspirant
Help! -Readynas Pro Business Edition - "Volume scan found errors that it could not easily correct. "
Twice in the past month the ReadyNAS has frozen while streaming video and became unresponsive. I held the power button in until it shut off then started up again and it went into the "Checking C:" routine. The first time it reported that it found errors and fixed them. The second time was last night and it has reported the following:
Volume scan found errors that it could not easily correct. Please ensure that you have current backups of all valuable data before performing a full volume scan by rebooting the NAS through Frontview with the volume scan option enabled.
***** File system check performed at Tue Sep 27 19:58:01 EDT 2016 ***** fsck 1.42.12 (29-Aug-2014) /dev/c/c was not cleanly unmounted, check forced. /dev/c/c: Deleted inode 17969165 has zero dtime. FIXED. /dev/c/c: Deleted inode 17969168 has zero dtime. FIXED. /dev/c/c: Duplicate or bad block in use! /dev/c/c: Multiply-claimed block(s) in inode 17969169: 143908865 143908868 /dev/c/c: Multiply-claimed block(s) in inode 17985541: 143908865 143908868 /dev/c/c: (There are 2 inodes containing multiply-claimed blocks.) /dev/c/c: File /.squeezeboxserver/cache/persist.db-wal (inode #17969169, mod time Tue Sep 27 18:41:42 2016) has 2 multiply-claimed block(s), shared with 1 file(s): /dev/c/c: /.squeezeboxserver/prefs/clientplaylist_00042023b69f.m3u (inode #17985541, mod time Sun Sep 4 19:30:24 2016) /dev/c/c: /dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options)
After receiving the email above I successfully shut the machine down normally and have not turned it back on.
I know next to nothing about the inner workings of the ReadyNAS OS. Would someone please be so kind to advise me as to what might be going on here and suggest any remedial steps to take.
ReadyNAS is populated with 5 - 1TB drives configured as X-RAID2 and is running RAIDiator 4.2.30
Thank you
Jim
Try booting it up using the "skip volume check" option on page 19-20 here: http://www.readynas.com/download/documentation/HM/ReadyNAS_Ultra_UltraPlus_Pro_HW_13April11.pdf
Then download the logs in case someone from Netgear wants to see them. Look at the disk health (health page, click on the SMART+ tab for each disk). And see if there are other disk-related errors - ATA counts, reallocated sectors, pending sectors, etc.
Don't change the file system contents either (don't add files, delete them, move them, etc).
Don't ignore this advice. Your data is clearly at risk.
1 Reply
