Numb3r6
Feb 13, 2019Apprentice
ReadyNAS Duo v1 boot fail into "Volume scan found and corrected errors"
This is a ReadyNAS Duo v1
-Bootup via Power Timer, as usual, no errors reported or emailed to me -First use of NAS was to stream music to a mobile device. Done it many times, no issues. This tim...
- Feb 15, 2019
I wouldn't be concerned about lp stat events.
A volume scan is a reasonable idea, though I'd suggest making a backup (or updating it if needed) first.
Feb 19, 2019Guru - Experienced User
Numb3r6 wrote:
This just in...its alive, well half of it says so.
After about 45 mins, system up and accessible.
That's good news. I suggest backing up the files before you insert the new disk.
Numb3r6
Feb 22, 2019Apprentice
Hopefully concluding this one now. Replacement disk synced up with no errors. No adverse log/SMART issues I can see.
Interestingly I hooked up the drive to a PC and tried the WD tools. It could see the drive, picked up on the allocation errors, but when I tried the repair option it was no go.
I've decided to leave the original Disk1 in place, if it's not broke etc. Also got a new spare 2TB WD Red, just in case.
Thanks for all your help StephenB
