Kodamitas's avatar
Kodamitas
Follower
Sep 24, 2020
ReadyNas Duo v1 firmware upgrade and disk replacement
Hello. I have an old RND2000v1 running 4.1.10. I’m about to replace one disk with a new Seagate Ironwolf 2TB. Thinking I should upgrade the firmware to 4.1.16. Any pros and/or cons to go to the new version? I downloaded the firmware, haven’t tried to upgrade directly from FrontView. Should I upgrade before or after adding the disk? Right now running degraded with just one disk.
  • StephenB's avatar
    Either way should work, but in your case I'd upgrade afterwards.  Most of the changes after 4.1.10 were security fixes.
ProSupport for Business
