JTJT
Jan 09, 2020Aspirant
ReadyNAS Duo v1 NIC failure?
Hi there I have a ReadyNAS Duo v1 with 2x2TB drives. I have been unable to connect to it for a week or so.... and I have tried: - - connecting it to 2 different routers and different ports on t...
- Jan 09, 2020
JTJT wrote:
Any help or other options would be greatly appreciated
Let's start with this. If you have a USB adapter/dock you can power down the NAS and connect disk 1 of the NAS to a Windows PC. Then use R-linux for Windows to offload the data. https://www.r-studio.com/free-linux-recovery/
JTJT wrote:
1. Mount the old drives in the new chassis, but will that even allow me to get access to the data? Or is there a specific process I should follow to do this?
If there is no damage to the RAID array on the disk this is possible. If the firmware on the "new" chassis isn't the same as what is installed on the disks, then the "new" system will install whatever firmware it is running onto the disks when you boot it up. It would be good to avoid this (or at least eliminate the possibility that you are downgrading firmware).
So the first thing to do is get a scratch disk (not from the array), install it in the new Duo, and let it set up. After that, install the same version of firmware that was on the "old" Duo. If you don't know the firmware, install 4.1.16.
Note that if the working Duo runs 5.x.x firmware or 4.2.x firmware, then it isn't a Duo v1, and it can't be used for recovery.
After installing the firmware, power down, remove the scratch disk, and put disk 2 of the array into slot 2. Power up using the boot menu to skip the volume check, as you don't want the system to attempt to repair any damage (as it could result in data loss). See pages 15-16 here: http://www.downloads.netgear.com/files/GDC/RND2110/Duov1_NV+v1_HW_en_06Dec11.pdf
I'm suggesting disk 2 because
(a) it preserves one of the disks for other possible recovery attempts
(b) RAID recovery software and R-linux for Windows have trouble with the Duo v1's "parity" disk - which is usually disk 2. So it's best to preserve disk 1.
JTJT wrote:
2. Would it be better to take the NIC out of the working device and put it the old one?
I wouldn't do that. If you find after data recovery that the "working" device isn't quite working, then you could try it I guess.
Sandshark
Jan 09, 2020Sensei
While the connector a a few passive components are on the daughterboard, the tranceiver is on the main board, and it's your most likely culpret. So, there is little point in even trying unless you find that the new NAS has a problem. The entire OS is on the drives, so there is nothing you need to "save" from the old chassis.
