2ndNAS
May 01, 2023Apprentice
ReadyNAS Duo v1 resynch hang.
After creating a new share on my RN202 I went on and created a rsync backup job on the Duo. I saw that snapshots needed to be excluded, so cancelled the backup job. The Duo advised that I should re...
- May 02, 2023
2ndNAS wrote:
According to WD diagnostic tool both disks are fine.
I suppose the next option is Reinstall firmware and/or Reset to factory defaults?
I'd probably just do the factory default.
You could also try just reinserting one disk (in its original slot) and booting up.
- If that works, see if the data is there. If it is, hot-insert the second disk and wait for the resync.
- If not, power down and try the other disk (by itself).
If both fail, just move on to the factory default.
May 01, 2023Guru - Experienced User
2ndNAS wrote:
Is it advisable to power off and hope the server will be OK after reboot,
If it doesn't resolve, at some point you will have to.
Have you tried logging in with ssh?
- 2ndNASMay 01, 2023Apprentice
Hello StephenB, thanks for responding.
Putty could not connect to my Duo, so I figured that next step should be testing the disks using WD diagnostics tool. I have used it before so no problem, but it does take some hours per disk. Follow-up tomorrow.
- 2ndNASMay 02, 2023Apprentice
- StephenBMay 02, 2023Guru - Experienced User
