2ndNAS
May 01, 2023Apprentice
ReadyNAS Duo v1 resynch hang.
After creating a new share on my RN202 I went on and created a rsync backup job on the Duo. I saw that snapshots needed to be excluded, so cancelled the backup job. The Duo advised that I should re...
- May 02, 2023
2ndNAS wrote:
According to WD diagnostic tool both disks are fine.
I suppose the next option is Reinstall firmware and/or Reset to factory defaults?
I'd probably just do the factory default.
You could also try just reinserting one disk (in its original slot) and booting up.
- If that works, see if the data is there. If it is, hot-insert the second disk and wait for the resync.
- If not, power down and try the other disk (by itself).
If both fail, just move on to the factory default.
