2ndNAS
May 01, 2023Apprentice
ReadyNAS Duo v1 resynch hang.
After creating a new share on my RN202 I went on and created a rsync backup job on the Duo. I saw that snapshots needed to be excluded, so cancelled the backup job. The Duo advised that I should re...
- May 02, 2023
2ndNAS wrote:
According to WD diagnostic tool both disks are fine.
I suppose the next option is Reinstall firmware and/or Reset to factory defaults?
I'd probably just do the factory default.
You could also try just reinserting one disk (in its original slot) and booting up.
- If that works, see if the data is there. If it is, hot-insert the second disk and wait for the resync.
- If not, power down and try the other disk (by itself).
If both fail, just move on to the factory default.
2ndNAS
May 02, 2023Apprentice
May 02, 2023Guru - Experienced User
- 2ndNASMay 02, 2023Apprentice
Followed your advice, and first disk works in the Duo.
Inserted second disk, and resync hang again.
I will use WD diagnostic to erase the second disk and see what happens when it's put back in the Duo.
- StephenBMay 02, 2023Guru - Experienced User
It sounds like it could be a failing 2nd disk. I've had disks that pass the long non-destructive test, but fail the write zeros/full erase test.
Last time I checked, the WD dashboard didn't include the erase test (the older Lifeguard software did).
- 2ndNASMay 03, 2023Apprentice
I do use the older SW and have not found problems with old disks.
A new disk is on order, I'm just trying to learn about this error. Do you know if my Performance Options might have any influence on the hang:
Disable full data journaling (not ticked)
Disable journaling (ticked)
Enable fast CIFS writes (ticked)
Again, thanks for your help.
