2ndNAS
May 01, 2023Apprentice
ReadyNAS Duo v1 resynch hang.
After creating a new share on my RN202 I went on and created a rsync backup job on the Duo. I saw that snapshots needed to be excluded, so cancelled the backup job. The Duo advised that I should re...
- May 02, 2023
2ndNAS wrote:
According to WD diagnostic tool both disks are fine.
I suppose the next option is Reinstall firmware and/or Reset to factory defaults?
I'd probably just do the factory default.
You could also try just reinserting one disk (in its original slot) and booting up.
- If that works, see if the data is there. If it is, hot-insert the second disk and wait for the resync.
- If not, power down and try the other disk (by itself).
If both fail, just move on to the factory default.
2ndNAS
May 02, 2023Apprentice
Followed your advice, and first disk works in the Duo.
Inserted second disk, and resync hang again.
I will use WD diagnostic to erase the second disk and see what happens when it's put back in the Duo.
May 02, 2023Guru - Experienced User
It sounds like it could be a failing 2nd disk. I've had disks that pass the long non-destructive test, but fail the write zeros/full erase test.
Last time I checked, the WD dashboard didn't include the erase test (the older Lifeguard software did).
- 2ndNASMay 03, 2023Apprentice
I do use the older SW and have not found problems with old disks.
A new disk is on order, I'm just trying to learn about this error. Do you know if my Performance Options might have any influence on the hang:
Disable full data journaling (not ticked)
Disable journaling (ticked)
Enable fast CIFS writes (ticked)
Again, thanks for your help.
- StephenBMay 03, 2023Guru - Experienced User
It shouldn't. The resync is just the RAID re-mirroring the two disks (copying each sector from one to the other in the case or RAID-1).
And you also used the full write-zeros test in Lifeguard?
Also what disks are you using? Many new drives 2 TB and under are SMR. They can have very slow sustained write times, so operations like resync could take quite a while.
I used the FULL erase function, but I don't know the kind of data it writes.
My disks are WD20EFRX and I have spend some time educating myself about the difference between WD20EFAX and WD20EFZX, and then what is CMR vs SMR. I suppose the compatibility-list is no longer updated, so I have chosen to stay with the CMR version.
Thanks again for your help.
