PuyRobin
Mar 16, 2025Aspirant
ReadyNAS Duo v1
Hello, I have an old ReadyNAS Duo v1 with 2 1tb drive set to raid 0. I'm looking to upgrade it, cost appropriate. I'm wondering if there is something around i can just pop the drives into with out l...
PuyRobin
Mar 18, 2025Aspirant
So I can not just drop the drives into a new NAS, your solution seems very long winded and costly as I would need new drives + new NAS caddy.
Mar 18, 2025Guru - Experienced User
There is no compatible new NAS. Netgear stopped manufacturing compatible ReadyNAS back in 2011. Another thing to consider is the age of your drives.
Do you actually need a NAS?
If not, you could just copy all your files over the network to storage connected to your PC. 4 TB isn't much storage by modern standards.
