j666gak
Mar 24, 2018Tutor
ReadyNAS Duo v2 - Hardware pins do what?
Hi, I hope that somebody can help me. Basically, I am looking for information as to which pin does what on the connector from the board that power button mounted on it, connecting to the mainboar...
Mar 28, 2018Guru - Experienced User
Also, make sure you have a duo v2.
A duo v1
- runs 4.1.x firmware
- has a -100XXX at the end of the part number (XXX might be NAS or a country code)
- might say duo v2 on the rear label (leading to much confusion).
A duo v2
- runs 5.3.x firmware
- has a -200XXX at the end of the part number
- says duo v2 on the front (at the bottom)
j666gak
Mar 28, 2018Tutor
Hi guys,
Thanks for the reply, I have added information below in reply
RND2150 v2
FW: v4.1.16
It is the pins on the board below that I am looking for, which I have highlighted in the red box
