j666gak
Mar 24, 2018Tutor
ReadyNAS Duo v2 - Hardware pins do what?
Hi, I hope that somebody can help me. Basically, I am looking for information as to which pin does what on the connector from the board that power button mounted on it, connecting to the mainboar...
Sandshark
Mar 29, 2018Sensei
Netgear has released no schematics or repair manuals for any NAS. I don't have a Duo V1, but that appears to be a double-sided board that you could follow the traces on. At the very worst, you could buzz them out. From what I can see in the picture, the connector on the left is for the LEDs and buttons and the one on the right is the USB. What is your end goal here?
j666gak
Mar 30, 2018Tutor
Sandshark Thanks for the reply.
Basically, I have installed and setup an SBC within the ReadyNAS enclosure/case which is all fine. Then what I wanted to do is connect the front power button and LEDs to the GPIO pins on the SBC. Which is why I wanted to know which pin relates to what.
When I am home next I will try connecting to pins and will work it out, I was trying to plan ahead asking for documentation.
Thanks
