JohnBeals
May 23, 2012Aspirant
ReadyNAS Duo v2 died in 5 days
I bought a new ReadyNAS Duo V2 Diskless system on the 17th. Yesterday the 22nd I came home from work and the ReadyNAS was powered down. After researching here and trying to power it up I checked the p...
mdgm-ntgr
May 23, 2012NETGEAR Employee Retired
Can you confirm its a Duo v2 by looking at How to tell whether I have a Duo v1 or Duo v2 or NV+ v1 or NV+ v2?
Take a look at http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
Don't plug a 3rd party power supply in. If the power supply is incompatible and causes damage it will void the warranty.
