claynz's avatar
claynz
Guide
Dec 14, 2019
ReadyNAS Duo V2 Firmware
Hi, not sure if my model NAS is a ReadyNAS Duo V1 or ReadyNAS Duo V2 and have attached an image for verification. I am trying to update the firmware from v4.1.13 to to v4.1.16 as found when checking...
  • JohnCM_S's avatar
    Dec 14, 2019
    Hi claynz,
    Your NAS is a ReadyNAS Duo v1 based on the firmware on it. Duo v1 runs on RAIDiator 4.1.x while the Duo v2 runs on 5.3.x.
    Have you tried manually uploading the firmware to the NAS? If not, you may try that and see if it will proceed with the update.
    You may download the 4.1.16 firmware here. Open the zip file then extract the firmware file from it.
ProSupport for Business
