boomish
Sep 26, 2013Aspirant
ReadyNas Duo V2 hard disk upgrade suggestions?
I have 2 Samsung SAMSUNG HD154UI 1.5 tb drives in there and they are nearly full m, any suggestions on upgrading these? sifting through the forums I can't see and large suggestions like 3TB..WD Red se...
mdgm-ntgr
Sep 26, 2013NETGEAR Employee Retired
Do you have a v1 or v2? Your forum join date and the RAIDiator version in your signature indicate that you have a v1. Please confirm by reading http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The RAM can only be upgraded on the v1. However the v1 does not support drives with larger capacity than 2TB. If you have the v1 and need more space it's probably time to get a new NAS and to use the v1 to backup important files.
