eusebio84
Oct 22, 2024Aspirant
readynas duo v2 ssh connection
Hello I have a readynas duo v2 and I have a problem with it because: - when I log in via ssh to the console, I can't do anything there, i.e. basic Linux commands don't want to work, among others: su...
Oct 22, 2024Guru - Experienced User
eusebio84 wrote:
- when I log in via ssh to the console, I can't do anything there, i.e. basic Linux commands don't want to work, among others: sudo, mkdir, etc.
Log in as root, using the NAS admin password.
eusebio84
I always log in this way.
- StephenBOct 22, 2024Guru - Experienced User
eusebio84 wrote:
I always log in this way.What firmware are you running?
Are you able to access the files on the NAS?
- eusebio84Oct 23, 2024AspirantI have the software raidiator 5.3.13 and I also have access to the files, I added a user and I can easily copy files from Windows etc. over the network when you add NAS to your computer as a network share.
- StephenBOct 23, 2024Guru - Experienced User
eusebio84 wrote:
I have the software raidiator 5.3.13 and I also have access to the files, I added a user and I can easily copy files from Windows etc. over the network when you add NAS to your computer as a network share.If you are logging in as root, then there is no need for sudo. Not sure about the v2 NAS (I never owned one), but other ReadyNAS systems don't have it. But mkdir should work.
It's not that surprising that there are issues with apt, since the version of linux used by the NAS is no longer supported. It shipped with Debian Squeeze - not sure if Netgear migrated it to Wheezy later on or not. Either way, archived years ago, so a lot of new packages won't install.
You could try powering down, removing the disk(s), and doing a fresh install on a spare disk. Then see if you get the same behavior with the spare. Just power down before reinserting the operational disk(s).
