JJNas24
Sep 27, 2019Aspirant
ReadyNAS Duo v2
Hello, everybody, i have a RN Duo v2 with two 3TB WD red disks, Radiator 5.3.13. The disk in shaft 1 failed. New 3TB WD red ordered and installed. Sync runs for about 8 hours, is then stopped wit...
- Oct 09, 2019
JJNas24 wrote:I have done the full erase.
After that i have inserted the new disk again in slot1, rebuild starts and ends with same problem
Same mdstat.log?
JJNas24 wrote:
Do you have another idea?
Do a full backup. Then do a factory install with all disks in place, and confirm that the RAID array is correct. Then reconfigure the NAS, and restore the data from backup.
A variant is to do the factory install with only the new disk in slot 1, and confirm that is ok. Then hot-insert the remaining disks one at a time.
schumaku
Feb 08, 2024Guru - Experienced User
red2design wrote:
... Netgear ReadyNAS Duo v2 RND2000-200EUS (working) and recently had a new Asus router. I now can't connect to the ReadyNAS Duo v2 where all my work is stored, ...
Same IP address, and same IP subnet, as before on the original router and LAN? Static IP configured (as before), and adopted the previous router LAN IP subnet addressing?
red2design
Feb 08, 2024Aspirant
Hi and thank you for replying. Yes with help from my ISP...
"Try changing the LAN IP to 192.168.2.1 and the DHCP start with 192.168.2.20 ending address 192.168.2.200. Hopefully then you will be in the same subnet as the Netgear NAS."
This is showing me more, I can see folders called admin, backup, home, media and share BUT I can't see my Work!!
- schumakuFeb 08, 2024Guru - Experienced User
So try to access the ReadyNAS admin Web UI http://192.168.2.xxx/admin/
- red2designFeb 08, 2024Aspirant
OK I have tried that but I get a 'Device is offline' box appearing in my browser and then limited Dashboard items behind that. The device is on with blue lights showing, it's plugged into the router too, just how it was with the old router.
- StephenBFeb 08, 2024Guru - Experienced User
Likely are you aren't using the same credentials as you were before. What happens if you look deeper into "home"? You should see a few usernames there (admin for sure). Look in those and see if you see your folders.
