Retired_Member
Mar 28, 2020Readynas duo V2
Hi Everyone I really hope some can really help me as I am stressing out over my ReadyNas Duo V2 with 2 X 2TB Western Digital WD20EFRX WD Red disks. Over recent weeks I have noticed that I lo...
Retired_Member
Mar 28, 2020Hi
The firmware is 5.3.11. I am trying to update it to 5.3.13 however have had issues.
I understand that ATA errors can occur when the NAS has to be powered down forcefully which is what I have had to do when it has become unresponsive.
So maybe the disks are still ok. Anyhow I am not taking the risk, I am currently taking the data off and moving to the cloud and have already ordered some replacement disks and will plan to factory reset the device once the data is off.
One thing that I would like to know is if there is anywhere (I assume using SSH) that I could get useful information to help me understand the root cause of the issue, why does the NAS suddently freeze. I like to know that so I can plan better for the future.
Many Thanks
Sandshark
Mar 28, 2020Sensei
Actually, you can get a lot of information from the logs in the downloaded logs .zip file. To get more information from SSH, the best thing is to have an open SSH session all the time so you can use it when the problem occurs. The execute top and see if something is taking up an inordinate amount of CPU time.
