Almeidosk
Sep 01, 2021Aspirant
Readynas DUO V2
Hi there, Just a newbie in Readynas devices, so already had huge problems: - I had 2 HDD WD40 EFAX series (Not EFRX), and put them on the nas, as intended to, just out the hdd sleeve (0 km/mi...
- Sep 02, 2021
Almeidosk wrote:
Now I'm aware of the problems in using EFAX red nas series, however, this is not a big problem if I span data, since there is no SYNC between disks, as it is in RAID1.
We'll see. The issue can show up whenever you do enough sustained writes to the volume.
Almeidosk wrote:
I came along someone refering that intend to ask near the engineering dep to include some kind of routine inside software to unlock hard disks locked by NETGEAR nas devices, however, in no other place looks to be implemented.
It is possible to unlock them in a Windows PC or linux system with hdparm (connecting them with a USB adapter/dock or SATA).
The disks can be unlocked using hdparm with
# hdparm --security-unlock NETGEAR /dev/sda # hdparm --security-disable NETGEAR /dev/sda
/dev/sda would be the first drive in a duo v2 - the actual device path depends on the PC/Linux system to which you connect the drive.
OS 6 NAS don't include the secure erase feature.
Almeidosk
Sep 02, 2021Aspirant
It is a V2.
It had "Readynas duo V2" in the front, and it uses 5.3.13 Firmware.
Now I'm aware of the problems in using EFAX red nas series, however, this is not a big problem if I span data, since there is no SYNC between disks, as it is in RAID1. Like I did with WD Black + WD Red EFAX (Which had a /c and a /d device- each one with 3.6 Tb)
I see in several cases that the unlock could be made remotly, which of course is not in my knowledge to do it - Already tried in several forms and DIY on this forum.
So, what i want is to recover the access to HDD to use them even not in a NAS device.
Further assistance from netgear would be good, however it is a legacy device and even the problem could be replicated in any netgear device where user stops secure erasing in any form - or even a power loss, the solution should be given by NETGEAR.
Furthermore when I contacted WD about this issue they say that it is a NAS problem since it is the NAS who lock the disks - Which it is true.
So, the interest solely is to unlock the disks to use them on other system without raid.
Greets
Rui Almeida
Sep 02, 2021Guru - Experienced User
- AlmeidoskSep 02, 2021Aspirant
Thank you very very much!
The problem i had before it's that i didn't run as root so i must add "sudo" before "hdparm" and "voilá!"
both unlocked and ready to go to another system with no "raid1" :=
Greets
Rui Almeida
