Oldmanjud
Mar 07, 2025Aspirant
readynas duo v2
I know its an old unit and unsupported but i figure i'll ask anyway I can access my login page using IE with a VBS script and i have created shares that i can access by mapping a drive to the fol...
Mar 07, 2025Guru - Experienced User
Oldmanjud wrote:
My question is this when i see the unit in Network and double click it opens a bunch of folders labelled music pictures videos etc etc.
Those are DLNA media classifications - not folders. If you don't use DLNA you should probably just turn it off.
Oldmanjud wrote:
I can access my login page using IE with a VBS script and i have created shares that i can access by mapping a drive to the folders
There are other ways. Are you sure you have a Duo v2? The labels are quite confusing.
Check the front panel:
- The original (v1) Duo says "ReadyNAS Duo"
- The Duo v2 says "ReadyNas Duo v2"
Oldmanjud
Mar 13, 2025Aspirant
Hi again
So i originally installed a 1tb drive and was able to map a drive to it, i then copied a bunch of files to it
BUT then i decided to upgrade to 2 lots of 4tb drive, i set them as Raid auto however i then realised i needed files that were on the 1tb drive, so i thought thats ok ill shut the nas down and just reinsert the 1tb drive on its own
but now although i can see the shared folder in the admin page if i run Raidar and click browse it opens up the shares in windows explorer but i cant access any of the shared folders all i get is windows cant access \\192.168.... etc
I have tried mapping drives using net use command and the same again, is there anyway to get to the music folder on the 1tb drive?
- StephenBMar 13, 2025Guru - Experienced User
Oldmanjud wrote: readynas duo v2Once again, are you certain you have a Duo v2? Check the front panel:
This matters, as the original Duo doesn't support drives bigger than 2 TB. It won't detect the proper size, and you will end up with a much smaller volume.
So you powered down, removed both 4 TB drives.
- Did you power up with both bays empty and then insert the 1 TB drive?
- Or did you insert the 1 TB when the NAS was powered down, and then powered up?
Can you still access the NAS web ui?
- OldmanjudMar 13, 2025Aspirant
I powered down the system removed the 2 lots of 4tb and then installed the 1tb drive then powered on, I assumed that it would just boot back up as it was when i first did it and that the music folder would be accessible
Also i cannot create a new share on the drive, so it seems that the system isnt seeing the drive correctly
