Martinsul
Apr 29, 2022Aspirant
ReadyNAS Duo
Netgear I have a ReadyNAS Duo v2 - this recently suffered a faulty disc, which I have replaced and carried out a factory reset, and also a OS reinstall. RAIDar opens with the correct IP ad...
Apr 29, 2022Guru - Experienced User
Martinsul wrote:
Unable to get to the Dashboard at all. Tried everything!
Are you getting an SSL protocol version mismatch error in the browser?
Perhaps try an older version of FireFox (version 94.0.2 will get past the protocol version mismatch). Make sure you immediately change the browser settings so it does not autoupdate.
US english version for Mac is here: https://ftp.mozilla.org/pub/firefox/releases/94.0.2/mac/en-US/
Martinsul
Thank you, strange but not on the Mac, but when I tried on a Windows 11 laptop, I did get a message in Firefox to say that the webpage did not meet the required security…
- StephenBApr 29, 2022Guru - Experienced User
I still recommend trying an old version of firefox, and see if that makes a difference.
There is an add-on from rnxtras.com that installs TLS 1.2 (which solves the protocol mismatch), but you need access to the web ui to install it.
You'll find it here: https://github.com/rdynsxtrs/r5bin/blob/master/apache2/Apache2_2.2.34-arm-0.0.1.bin
- MartinsulMay 01, 2022Aspirant
Thank you, thank you. It worked!
I just need to find how I stop Firefox from updating…
- StephenBMay 01, 2022Guru - Experienced User
Per https://support.mozilla.org/en-US/kb/install-older-version-firefox:
By default, Firefox is set for automatic updates. To prevent Firefox from automatically updating itself after you install an older version, you'll need to change your Firefox update settings:
- Click the menu button and select Settings.
- In the General panel, go to the Firefox Updates section.
