Martinsul
Apr 29, 2022Aspirant
ReadyNAS Duo
Netgear I have a ReadyNAS Duo v2 - this recently suffered a faulty disc, which I have replaced and carried out a factory reset, and also a OS reinstall. RAIDar opens with the correct IP ad...
Martinsul
Thank you, strange but not on the Mac, but when I tried on a Windows 11 laptop, I did get a message in Firefox to say that the webpage did not meet the required security…
Apr 29, 2022Guru - Experienced User
I still recommend trying an old version of firefox, and see if that makes a difference.
There is an add-on from rnxtras.com that installs TLS 1.2 (which solves the protocol mismatch), but you need access to the web ui to install it.
You'll find it here: https://github.com/rdynsxtrs/r5bin/blob/master/apache2/Apache2_2.2.34-arm-0.0.1.bin
- MartinsulMay 01, 2022Aspirant
Thank you, thank you. It worked!
I just need to find how I stop Firefox from updating…
- StephenBMay 01, 2022Guru - Experienced User
Per https://support.mozilla.org/en-US/kb/install-older-version-firefox:
By default, Firefox is set for automatic updates. To prevent Firefox from automatically updating itself after you install an older version, you'll need to change your Firefox update settings:
- Click the menu button and select Settings.
- In the General panel, go to the Firefox Updates section.
