Cliff_MI
Nov 10, 2021Guide
ReadyNAS Management services offline
I have a ReadyNAS 3100 that is off line. I can't get into it at all. It refuses SSH. The Webpage hangs up and does not load. I have tried a OS reload, but I don't think that worked. It is run...
Cliff_MI
Nov 11, 2021Guide
i see this error in the readynasd.log
Nov 10 18:12:07 southbackup readynasd[2963]: readynasd log started
Nov 10 18:12:08 southbackup readynasd[2963]: readynasd started. (restarted=0)
Nov 10 18:12:09 southbackup readynasd[2963]: Error rndb_import() ==> rc=3
Nov 10 18:12:09 southbackup readynasd[2963]: dba import failed
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd log started
Nov 10 18:12:10 southbackup readynasd[3030]: readynasd started. (restarted=0)
Nov 10 18:12:12 southbackup readynasd[3030]: Error rndb_import() ==> rc=3
Nov 10 18:12:12 southbackup readynasd[3030]: dba import failed
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd log started
Nov 10 18:12:12 southbackup readynasd[3094]: readynasd started. (restarted=0)
Nov 10 18:12:13 southbackup readynasd[3094]: Error rndb_import() ==> rc=3
Nov 10 18:12:13 southbackup readynasd[3094]: dba import failed
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd log started
Nov 10 18:12:13 southbackup readynasd[3151]: readynasd started. (restarted=0)
Nov 10 18:12:14 southbackup readynasd[3151]: Error rndb_import() ==> rc=3
Nov 10 18:12:14 southbackup readynasd[3151]: dba import failed
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd log started
Nov 10 18:12:14 southbackup readynasd[3208]: readynasd started. (restarted=0)
Nov 10 18:12:15 southbackup readynasd[3208]: Error rndb_import() ==> rc=3
Nov 10 18:12:15 southbackup readynasd[3208]: dba import failed
Not sure what that means.
Sandshark
Nov 11, 2021Sensei
Have you received any messages regarding a full or nearly full OS partition? How full is /dev/md0 showing in the === df -h === section (near the bottom) of volume.log?
- Cliff_MINov 11, 2021Guide
I did not get any errors and it shows that the root folder is only 34% full.
Thanks for any suggestions
=== df -h ===
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 1.3G 2.4G 34% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 1.4M 2.0G 1% /run
tmpfs 987M 1.7M 985M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
/dev/md127 5.5T 789G 4.7T 15% /data
/dev/md127 5.5T 789G 4.7T 15% /home
/dev/md127 5.5T 789G 4.7T 15% /apps
=== df -i ===
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 504287 441 503846 1% /dev
/dev/md0 0 0 0 - /
tmpfs 504957 1 504956 1% /dev/shm
tmpfs 504957 581 504376 1% /run
tmpfs 504957 69 504888 1% /run/lock
tmpfs 504957 15 504942 1% /sys/fs/cgroup
/dev/md127 0 0 0 - /data
/dev/md127 0 0 0 - /home
/dev/md127 0 0 0 - /apps
- Jun 10, 2022Retired_Member
