Rich17's avatar
Rich17
ReadyNAS NV - Can't connect
Bought in 2006 as Infrant ReadyNAS NV, and it worked well until now. I replaced a couple failed disks over the years with no problem. Last week my ATT fiber gateway was replaced last week and now th...
  • Rich17's avatar
    Rich17
    Jan 21, 2021
    The ReadyNAS NV started up fine and is running on it's original RAID disks, and thankfully, I was able to get all the data copied off of the NAS!  Thanks to everyone on the thread for your assistance!   :smileyvery-happy:
    One weird thing:
    With the test disk installed, Raidar showed the NAS was running on lastest firmware.
    But with the old RAID array disks installed the firmware version shown in Raidar now says it's still running firmware "4.01c1-p1"    The NAS has not updated the old disks to the newer software. I will retire it now anyway so doesn't matter.
    I would like to make a donation in thanks for your assistance StephenB. Can you PM your paypal addy?
    Thanks
    Rich
ProSupport for Business
