Rich17
Dec 24, 2020Aspirant
ReadyNAS NV - Can't connect
Bought in 2006 as Infrant ReadyNAS NV, and it worked well until now. I replaced a couple failed disks over the years with no problem. Last week my ATT fiber gateway was replaced last week and now th...
- Jan 21, 2021
The ReadyNAS NV started up fine and is running on it's original RAID disks, and thankfully, I was able to get all the data copied off of the NAS! Thanks to everyone on the thread for your assistance! :smileyvery-happy:
One weird thing:
With the test disk installed, Raidar showed the NAS was running on lastest firmware.
But with the old RAID array disks installed the firmware version shown in Raidar now says it's still running firmware "4.01c1-p1" The NAS has not updated the old disks to the newer software. I will retire it now anyway so doesn't matter.
I would like to make a donation in thanks for your assistance StephenB. Can you PM your paypal addy?
Thanks
Rich
Rich17
Netgear Customer Support can't help me since my Infrant ReadyNAS did not come with a serial number! I bought it from Amazon in 2006, but the serial plate is blank. So I'm very appreciative of the support here on the forum.
I just purchased a used Infrant ReadyNAS NV from ebay seller, he said it works and ebay gives money back guarantee, so hopefully that will work out.
Is there anything I should do to the "new" unit before I install my drives and power it up?
Should I do a factory reset on it first?
Should I install a single scratch drive to see if it works?
Thanks for any ideas
Rich
Dec 24, 2020Guru - Experienced User
If the firmware install image in the flash doesn't match the OS on the drives (which is almost a certainty), then the boot loader will attempt to install whatever firmware is in the flash onto the drives. That could be a problem, as there are some downgrades that could result in data loss.
Normally I'd tell you to do a factory install on a scratch disk first, and then update the same firmware as you had on the old NAS. But unfortunately, you don't know what firmware that was. So what you need to do instead is update the firmware to the currently shipping version (which is 4.1.16): https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc. Extract the binary from the zip, and then install that binary with frontview.
After that I suggest making sure that all the bays in the replacement NAS work. You can easily test that by booting up the NAS with the scratch disk in each slot. If that works, then migrate your original disks (keeping them in slot order). The migration process will then also update the OS on the disks to 4.1.16.
No, and in fact you can't. The factory reset installs the OS onto the disks from the flash install image. That simply can't be done if there are no disks installed.
