beichst
Jan 05, 2013Aspirant
ReadyNAS NV+ - Received "Access to the disk on channel (??)"
Hello. I believe I need to replace a disk and would like to confirm that disk 4 is the likely suspect. The error message could not confirm the channel error. I have four 2TB WD20EARS - 00MVWB0 d...
Jan 06, 2013Guru - Experienced User
Drive 4 is likely the culprit, though if you have a USB drive connected it conceivable could be that.
Red drives are definitely better for RAID use than the Green. They also have a longer warranty.
