MInDev
Dec 06, 2020Aspirant
ReadyNAS NV+ blinking blue and green LEDs
My ReadyNAS NV+ has developed a fault. The blue power LED is flashing at inverals of about once per second, and one of the two HD LEDs is flashing at the same rate. I can ping the ReadyNAS, but I...
- Dec 07, 2020
MInDev wrote:
Assuming I go down this route and acquire another 1TB drive, is it best to leave the ReadyNAS powered on with the existing drive connected when I plug it in the new drive to begin the RAID creation process?
I do recommend doing a hot-insert (with the NAS running). The benefit of doing a hot-insert or a hot-swap is that the NAS detects exactly what is happening. If you do it with the NAS powered down, then it needs to figure out what changed.
Though doing it powered down generally does work too.
Dec 07, 2020Guru - Experienced User
MInDev
Dec 15, 2020Aspirant
Thank you again (and sorry for the late reply). Having backed up everything to an external drive and taken delivery of a replacement hard disk, I will be doing exactly this today.
