fooprobe
Jul 20, 2016Aspirant
readynas nv+ dead, how to recover disks?
my trusty NV+ finallky quit. not in the serial number range for the PSU service action. i have a backup, but it's a hassle because the backup doesn't delete old folders when i move them around on t...
Marto731
Emil,
I take it power supply is dead. If you know someone with an active NV+, or search for a PSU.
The later x86 and ARM units are not compatible with Sparc NV+.
Regards, Marto
- fooprobeJul 20, 2016Aspirant
i don't know for certain that the PSU is dead but it looks like it. i get no lights at all, unresponsive.
i was afraid that's what you would say =( ok, thanks for the feedback.
- StephenBJul 21, 2016Guru - Experienced User
If you have a suitable linux machine (with enough connections for the disks) you could do this: http://home.bott.ca/webserver/?p=306
Note you can use a linux boot CD with an ordinary PC.
- fooprobeJul 21, 2016Aspirant
oh! interesting. i might be able to make that happen actually.... thanks!!
