fooprobe
Jul 20, 2016Aspirant
readynas nv+ dead, how to recover disks?
my trusty NV+ finallky quit. not in the serial number range for the PSU service action. i have a backup, but it's a hassle because the backup doesn't delete old folders when i move them around on t...
Jul 21, 2016Guru - Experienced User
If you have a suitable linux machine (with enough connections for the disks) you could do this: http://home.bott.ca/webserver/?p=306
Note you can use a linux boot CD with an ordinary PC.
fooprobe
Jul 21, 2016Aspirant
oh! interesting. i might be able to make that happen actually.... thanks!!
- BrianL2Jul 28, 2016NETGEAR Employee Retired
Hi fooprobe,
Were you able to mount your disks on a Linux machine to get your files?
Kind regards,
BrianL
NETGEAR Community Team- fooprobeAug 01, 2016Aspirant
I haven't had a chance to try it yet. I still need to get replacement storage up and running, and my personal life is in the way. If i get it working i'll let you know about it....
- BrianL2Aug 01, 2016NETGEAR Employee Retired
Hi fooprobe,
Alright then. Just keep us in the loop on what happens next.
Kind regards,
BrianL
