Jerry2011
Feb 18, 2012Aspirant
Readynas NV+ motherboard/case exchange
Hi everybody, today, my infrant NV+ brought 2006 went up in smoke - the motherboard is burned. How can I save my data? Hopefully, the pretty new 3x2TB harddisks in X-RAID configuration with my da...
mdgm-ntgr
Feb 18, 2012NETGEAR Employee Retired
Is your serial number in this range?: http://www.readynas.com/forum/viewtopic.php?t=10259
Are you located in the US?
Provided disks are fine, you can migrate to your other NV+ as both would be NV+ v1 units. See http://www.readynas.com/kb/faq/boot/how_do_i_migrate_disks_over_from_an_existing_readynas_to_another
Would be best to ensure you have the latest firmware installed on the unit you are migrating to.
