Jerry2011
Feb 18, 2012Aspirant
Readynas NV+ motherboard/case exchange
Hi everybody, today, my infrant NV+ brought 2006 went up in smoke - the motherboard is burned. How can I save my data? Hopefully, the pretty new 3x2TB harddisks in X-RAID configuration with my da...
Jerry2011
Feb 19, 2012Aspirant
Thanks for your answer!
a) In the kb-article is written: "Never migrate disks if your volume is in degraded mode. Make sure the volume is redundant first."
Of course the motherboard burned while the Device was up and running - I don't know if the device was in sleep mode or whatever. So most likely I can not tell if the disks are redundant now or not.
What should I do and how can I check this?
b) My SN on the burned device is 58552561347, so I'm in this affected group? I never heard of this problem, so it might be the reason why the device burned.
I will look for it on the other nv+. Thanks!
Best regards, Jerry
Best regards, Jerry
