Jerry2011
Feb 18, 2012Aspirant
Readynas NV+ motherboard/case exchange
Hi everybody, today, my infrant NV+ brought 2006 went up in smoke - the motherboard is burned. How can I save my data? Hopefully, the pretty new 3x2TB harddisks in X-RAID configuration with my da...
mdgm-ntgr
Feb 19, 2012NETGEAR Employee Retired
a) You can connect the disks up to an internal SATA port on your PC to check them. If they are fine then the array probably is redundant.
b.) Sounds like it's the PSU that's gone up in smoke. What region are you in (e.g. US). You could contact NetGear referring to the service action and see if they will issue a replacement PSU. Post your case/RMA number (whichever you get) preferably in the thread title (i.e. subject of first post in the thread).
Also take a look at this: http://www.readynas.com/kb/faq/hardware/how_do_i_replace_the_stock_power_supply_on_the_readynas_nv
If you remove the PSU you should be able to confirm it's the problem.
