Jerry2011
Feb 18, 2012Aspirant
Readynas NV+ motherboard/case exchange
Hi everybody, today, my infrant NV+ brought 2006 went up in smoke - the motherboard is burned. How can I save my data? Hopefully, the pretty new 3x2TB harddisks in X-RAID configuration with my da...
mdgm-ntgr
Feb 19, 2012NETGEAR Employee Retired
A number of users have had failed PSUs and after replacing them the NAS has been fine again (edit: should note that this may not necessarily always be the case, but usually is).
The RAID array can most likely be moved to another NV+ v1 unit. If your backup is not up to date and your data is important then you should consider cloning the disks just in case something goes wrong with the migration.
