jongrik
Aug 03, 2016Follower
ReadyNAS NV+. Replacing disk.
Hi all, This weekend a disk crashed of my readyNAS NV+ RND4000. (Disk 2) I replaced the disk with a new one. Bigger capacity etc. I read (guidelines) this was possible. The ReadyNAS doesn't rec...
Aug 03, 2016Guru - Experienced User
Was the disk volume using XRAID? If so you should be able to see the volume even with one disk failure.
What disk models are you using in the other slots? What replacement disk did you try first? What firmware is the NAS running?
BrianL2
Aug 03, 2016NETGEAR Employee Retired
Hi jongrik,
Welcome to the community!
In addition to StephenB' questions, when you put the drives in, did your system logged that new disk/s has been detected? You can check this information under Status -> Logs.
Kind regards,
BrianL
NETGEAR Community Team
