monkeyass
Apr 15, 2016Aspirant
Readynas NV+ SLOW TRANSFER
Hi Recently picked up a ReadyNas NV+. I have a Sky Hub as my main router which connects to a Netgear GS208 and all my ethernet connects go to this. When trying to transfer files from my Laptop to...
Apr 15, 2016Guru - Experienced User
What firmware is on the NV+?
Did you look for SMART errors on the disks and also packet errors on the NIC card?
- JennCApr 16, 2016NETGEAR Employee Retired
Hello monkeyass,
Is your laptop transferring files to the NAS via wireless? Please see if you get the same problem when you are connected via LAN cable to the same network where the NAS is. It is possible that if that is wireless, the slow connection has something to do with wireless signal.
Welcome to the community!
- JennCApr 19, 2016NETGEAR Employee Retired
Hello monkeyass,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!Regards,- monkeyassApr 19, 2016Aspirant
Hi
Ive turned off the wifi connection so its definately transfering via ethernet.
Firmware is RAIDiator 4.1.14
How do I check for SMART errors? Complete newbie at this NAS stuff.
- Jan 21, 2017Retired_Member
