monkeyass
Apr 15, 2016Aspirant
Readynas NV+ SLOW TRANSFER
Hi Recently picked up a ReadyNas NV+. I have a Sky Hub as my main router which connects to a Netgear GS208 and all my ethernet connects go to this. When trying to transfer files from my Laptop to...
Apr 15, 2016Guru - Experienced User
What firmware is on the NV+?
Did you look for SMART errors on the disks and also packet errors on the NIC card?
JennC
Apr 16, 2016NETGEAR Employee Retired
Hello monkeyass,
Is your laptop transferring files to the NAS via wireless? Please see if you get the same problem when you are connected via LAN cable to the same network where the NAS is. It is possible that if that is wireless, the slow connection has something to do with wireless signal.
Welcome to the community!
- Jan 21, 2017Retired_Member
