monkeyass
Apr 15, 2016Aspirant
Readynas NV+ SLOW TRANSFER
Hi Recently picked up a ReadyNas NV+. I have a Sky Hub as my main router which connects to a Netgear GS208 and all my ethernet connects go to this. When trying to transfer files from my Laptop to...
JennC
Apr 19, 2016NETGEAR Employee Retired
Hello monkeyass,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
monkeyass
Apr 19, 2016Aspirant
Hi
Ive turned off the wifi connection so its definately transfering via ethernet.
Firmware is RAIDiator 4.1.14
How do I check for SMART errors? Complete newbie at this NAS stuff.
- StephenBApr 19, 2016Guru - Experienced User
You look in the NAS admin UI - click on "status", then "health". There's a "smart+" button next to each drive, which will generate a pop-up when you click on it.
- JennCApr 19, 2016NETGEAR Employee Retired
Hello monkeyass,
Or from the logs, check reallocated sector, pending error and ATA error if you want to see if disks are still healthy.
Here:
- monkeyassApr 19, 2016Aspirant
No smart errors. All disks are healthy. Im wondering some settings may need altering or whether my Sky Hub is slowing it down, although I do have a giga switch inline
- Jan 21, 2017Retired_Member
